simulate water flow in a pipeline
Hello everbody,I have been trying to find a proper solution to simulate water flow or movement in a pipe/tube but I could not find the right things. Imagin the pipes going not only one way but up then to the right and down and so on. I would need to be able to control the flow in the sense that it schould only flow if a pump is running and I need to find a solution wich I can youse with many different pipe-structures.
Hopefully somebody can help.
Tank you very much,
montanaro
(3,005 Views)
do you mean graphical indicator? just simply create custom control/indicator and put some animated gif as water flows indicator will show gif and if dont there will be static image 🙂
(3,004 Views)
Hi montanaro,
You could place a transparent 2D picture indicator over your pipes and indicate the flow by changing what is "drawn" on the picture.
For example, you might draw a series of dashes and arrows to indicate the flow path.
To show motion, you would create a loop to replace dashes with arrows and vise versa.
This method could be adapted to any structure.
Please note that this task is not trivial - but with some effort it could be pretty cool.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,986 Views)
