simple login
can anyone sharing some vi's or idea on how to do a simple login file without using a sub vi?? i want to compare what the user input with a constant number. If it is correct, then it'll prompt "Correct", if wrong, "Wrong". It will verify when user press the ok button.
(5,204 Views)
Hi mahe,
here is an example for you.
Hope it helps.
Mike
(5,201 Views)
thnks mike.. but it keeps looping. i want it to be like, when it enter the correct password, it will prompt Correct, then let say it will continue to other form to enter some information. If it is not correct, then it will keep asking for the password
Message Edited by mahe on 04-26-2008 03:52 AM
(5,197 Views)
Hi mahe,
with this little modification, it do what you want.
Mike
Message Edited by MikeS81 on 04-28-2008 02:35 PM
(5,138 Views)
