signal prossesing and generetion
Hi I´m acquiring a voltage from a 60 Hz sinusoidal signal with NI USB-6363 in LabVIEW, so then i want to produce a pulse after a zero crossing in each semi-cycle with a phase delay with the same NI USB-6363, for example Labview detects a zero cross and 120° after of the crossing i want to produce a pulse with a rising time of 50us. The phase delay needs to be controlled.
P.S. The acquiring block that I´m using produces Dynamic Data
(2,539 Views)
(2,526 Views)
