signal filter
Is there a way to only get selected values from a signal? I am inputting data from a DAQ and would like to export each value only as i changes in the for loop. Right now, when I export the data there are many repeats of values.
VL
(3,463 Views)
Hi vrock,
yes, there's a way!
You know LabVIEW is a programming language? So you can program a small filter routine that will only pass values that changed compared to their predecessor...
Btw. that's a nice way to learn LabVIEW 🙂
(3,460 Views)
Thanks so much for your response! What block would I use to create a filter routine? Sorry, I'm knew to labview...
-VL
(3,456 Views)
Accepted by topic author vrock
Hi vrock,
for the beginning I would use a FOR loop, a shift register, a Case structure with a BuildArray node inside...
(3,453 Views)
How would I save a preceding value to use in the Case structure?
(3,450 Views)
Hi vrock,
I already advised to learn LabVIEW (NI offers free online courses!) and I already named shift registers...
(3,443 Views)
Hi vrock,
A shift register actually passes the last data (right side of loop) it received to the beginning of the loop (left side of loop). If you are familiar with text-based languages it is similar to an x = x + y instruction. www.ni.com/support has some good resources if you are new to LabVIEW and I would definitely recommend some online training course, as GerdW mentioned.
Tannerite
(3,421 Views)
