signal detection
Hi! Im currently working on an ultrassonic sensor using labview. So, i have a timer that starts when i send pulses and i want it to stop, when the receiver module of the sensor detects the ultrasound and transforms it onto a signal. My problem is that i dont know how to build an vi that stops my timer when it detects the signal from the receiver. Im using a data aquisition module for my work.
(3,214 Views)
Hi Warulf,
which DAQ module do you use? (Which DAQ hardware at all?)
What is the expected time interval?
In general you read in the analog signal of your transformer/receiver with a fixed sample rate. Once you read in the signal you can easily analyze it - as the samples come with a fixed rate/time interval you can use their index to calculate the time…
(3,212 Views)
im using an NI-622X, cant really tell you the last number since the the daq is on college lab.
(3,203 Views)
Hi Warulf,
go through all those example VIs coming with LabVIEW and DAQmx. There are example showing how to read in an analog signal with a fixed samplerate.
And there are examples for peak detection…
(3,198 Views)
