shut down PXI programmatically
Hello
I know there are ways to boot up or shut down a PXI (WoL for example) i dont know much about this method.
What im looking for is a way to shut down a PXIe 1071 chassy and 8135 CPU, programmatically using labview code.
any ideas would help
thanks!
(3,433 Views)
The functions you want can be found on the Real-Time Palette, RT Utilities, System Configuration.  Find Systems can return an array of the PXIs that it "sees" (convert the string output to a System Session using a TypeCast).  You can then feed this to Initialize Session, Restart, and Close, which should force the PXI to reboot itself.
(3,394 Views)
