show or hide plot
I’m a little new in the LabVIEW environment and I have a problem that I can’t solve.
I’m using a PCI6229 card to “read” several temperatures (10 different). These temperatures are plotted in a waveform chart. Now I want the ability to choose witch temperatures I want to see in the chart. For example I want plot 1 and plot 5 to be visible and the others not. Can anyone help me with this problem? I have tried to solve it with a property node but it doesn’t work.
If you have any questions at all about something that is not clear, please ask me.
Thanks in advance!
(2,787 Views)
Hi
The property node is the right way. Just have a look at the attachment.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,782 Views)
Thank you very much Thomas! My problem is solved thanks to you!
Mark
(2,783 Views)
