shift register
what is the fuction of the shift register..??
(3,266 Views)
Read Help
Step out of your comfort zone to experience the real you!
(3,259 Views)
For example,
                             If you want to pass a value between different states when you are working with case structures or for storing a value until the program shut down, you will use shift register. What I have seen in my past experience is, Shift register is one of the function can be used mostly in case if you are going for local variables.
Take a look at example here.
"Don't forgot to initialize the shift register before using"
(3,249 Views)
Or intentionally don't initialise the shift register, if you want to create an Action Engine
_____________________________
- Cheers, Ed
(3,245 Views)
Hi Nst,
In a simple manner, a shift register will be used to hold the previous iteration value.
Hope this vi will be helpful. Run the vi in highlight exen mode u can easily understand.
LV 8.0, 8.6, 2011,2012,2013 WinXP
(3,238 Views)
