shift register data type
Hi all!
I created vi called - shift reg, but whet I replace Add function with HTM Add function the shift register type doesn't change - vi called shift reg(2).
Could somebody explain me how this is done with shift regsters?
Cheers,
Evita
Message 1 of 15
(6,544 Views)
I recommend deleting all wires going to and from the shift register and then rewire them, starting with your initialization constant.  LabVIEW does sometimes get confused about the data types on shift registers in situations like this.
Message 2 of 15
(6,536 Views)
It doesn't help in this case.
Message 3 of 15
(6,526 Views)
Did you try manually changing the representation of that indicator too?
Rewiring with the correct datatypes should do the trick... Stick some conversion nodes in there as well if that doesn't work.
Edit: FYI, you can't have DBL on an FPGA anyways. I've had trouble in the past with the LV environment automatically outputting DBL. The key is just to put FXP conversion nodes when needed.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 4 of 15
(6,518 Views)
Yes, I tried also that.
The reason why I need shift registers type change from DBL to FXD, is that FPGA doesn't support DBL.
Message 5 of 15
(6,495 Views)
I know most, if not all, FPGAs do not support the double data type, but just to clarify, does your FPGA support singles?
Message 6 of 15
(6,485 Views)
Right... so have you tried inserting a FXP conversion node, then?
Cheers
Message 7 of 15
(6,484 Views)
I cannot use DBL data type at all in my vi, therefore I have to find another solution.
Message 8 of 15
(6,471 Views)
No, it also doesn't support singles.
Message 9 of 15
(6,465 Views)
Cheers
Message 10 of 15
(6,458 Views)
