shift in the sinus
I am testing a simple sinus signal transmission with a NI PXI/PCI-5401 generator card and a NI PCI-5911 Modular instrumentation card. The two vis, which I use to generate the  and acquire the sinus are attached. I wonder why one of the sinus amplitudes has a small "z" formed shift?
Ninskaya
(2,695 Views)
Hi ninskaya,
have you tried this signal transmission with the soft front panels.
Can you go a little bit in more detail what you mean with "small "z" fomed shift"? Zoom in, and make a picture from the signal or use anything to explain a bit more.
But first if I where you, I would try the Soft Front Panels.
Alex R
NI Switzerland
Link to duplicated Forum:
Message Edited by Alex R on 02-10-2006 02:53 PM
(2,669 Views)
