shared variables
Hello All,
I want use shared variables to share data in two PCs that I have.
I´m not understanding how can I make this, can somebody explain me how can i use this?
Regads
(2,975 Views)
Perhaps you could supply some more details?  Unless you need to share data between two programs that are running simultaneously, there are probably much simpler ways to do what you need.
Have you read this guide about Using the LabVIEW shared variable already?
You should also probably look at the Shared Variable Client-Server example that ships with LabVIEW.
(2,970 Views)
That is true, both programs are runing simultaneously, in both PCs the code must be very eficient, I was thinking that the shared variables ware a good solution for me.
Thanks in advance, best regards
(2,966 Views)
