shared variable
I want to transfer data across computers connected through internet. I am building a LabVIEW executable and using network published variables for communication between clients and a server because client may not have LabVIEW installation.  I referred this link:
http://zone.ni.com/reference/en-XX/help/371361B-01/lvhowto/building_a_stand_alone_app/
But I am unable to communicate even on intranet. Also, I am not sure about the implication of Note after step 7? Please elaborate.
Also, is this the best method for data transfer across the computers on internet? At every time instant, I need to transfer data from server to client, do some calculation at the client side, send it back to the server and repeat this procedure.
(4,477 Views)
Hi scilab_la...,
why did you use a different content in your link?
Did you try to build the application without using the steps after 7?
Another possibility is to use the TCP/IP functions to implement the communication.
Mike
(4,472 Views)
HI,
HAVE YOU FOLLOWED FOLLWING STEPS WHILE MAKING EXE?
SEE THIS : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIDuCAO&l=en-US
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,471 Views)
Sorry, I am giving the link again:
I built the executable without including the libraries. But it didn't work for me. I am not sure about the following:
(i) Changing the Destination of the .lvlib file to a destination outside the executable
(ii) To what destination?
(ii) How does this change accomodate the network shared variables?
I am using LabVIEW 8.0.
Thanks.
Message Edited by scilab_labview_user on 07-18-2009 04:44 AM
(4,447 Views)
(4,415 Views)
(4,408 Views)
