shared variable read
Hello, everyone,
I'm trying to use shared variable read function to read all the I/O channels in the analog input module Mod1 as an array of doubles as follows, it works for the modules like 9235, 9237 in the cRIO 9035, however, it does not work on modules which inserted on 9149 ethernet RIO. My cRIO 9035 and 9149 are connected, in the same project. Thanks in advance if anyone can help with this.
(2,881 Views)
Hi Xiao,
I think you might be having a similar problem as to the one in this forum post: https://forums.ni.com/t5/LabVIEW/Scanned-variable-read-function-all-channels/m-p/3794508#M1070672
(2,845 Views)
