shared variable does not work between two computers
I am using LabVIEW 8 on Windows XP computers.
1. On one computer I have created two projects, writeProject and readProject.
2.  In the writeProject I have a shared variable, writeData, which is "network-published" double. In this project I have a writeData.vi which in while loop assigns a random value to the writeData variable.
3. In the readProject I have a shared variable, readData, which is "network-published" double and is bound to the writeData variable.  This is on the same computer as the writeProject.
4. I run both the writeData.vi and the readData.vi and all works fine.
5. Now, I create a readProject on a diferent computer.  Perform all the steps as described above and also in tools/shared variable/register computer, I have entered the IP address of the target computer on which the writeData shared variable exists.
6. Binding the readData variable fails in the following way.  When I browse for the source, in the "Select Source Item" dialog, I see <IP> <Populating Node...>, where <IP> is the IP address of the source computer (on which exists the writeData shared variable).  A very long time later it is still "Populating Node...".  Neddless to say, this readData.vi does not work!
What am I doing wrong?  Or, perhapse what else do I need to do to make it work?
(3,018 Views)
I would suggest checking out the two KnowledgeBases I have linked below for common issues with Network Shared Variables. Let me know the results. Thanks!
Troubleshooting Network-Published Shared Variables
Why Are My Network Shared Variables Taking Very Long to Initialize?
Stephanie
(3,006 Views)
Thanks Stephanie,
The issue was with the fire wall.  Putting the few programs in the fire wall exceptions list fixed my problem.
Thanks again,
Zen
(2,995 Views)
