shared variable control
Hello
I use a shared variable to read from an OPC server, this is a wind speed and it give me a value in m/s.
Which control can I make on this value and how can display a short message in case of error?
thanks
(2,642 Views)
Hi enzo78,
do you mean if the error output of the shared varible is set? What do you mean with "which control can..."? I thought you can see the value. Smiley Happy The easiest way is to right clock in the shared variable and select create -> create indicator. Smiley Happy
Mike
(2,637 Views)
