shared library (DLL) with pointer array
hi all,
I have a DLL coded in C++ and I want to use the share library tools to generate the corresponding library. I use Labview 2011 (32 bits). Here is the function as defined in the  *.h file:
TESTSHARED_EXPORT int Validation_TEST(double * const data, const int N);
But in the 'configure VIs and controls' window (see attached screenshot), I cannot select 'Array' as 'control type' for the 'data' parameter.
any suggestions?
Cedric
(2,819 Views)
Hi Cedric,
I believe that this may help you with what you're trying to do.
https://www.ni.com/docs/en-US/bundle/labview/page/example-importing-functions-from-a-shared-library-...
Hope this helps.
Taylor
(2,770 Views)
