share memory
I nedd to use share memory in Linux. Can I use it in LabVIEW for Linux?
(2,830 Views)
Hello Lidia,
I'm not sure how this can be done in Linux, so my suggestions are:
a) Go here and start a Linux support request:
http://www.ni.com/linux/lin_tech.htm
b) If performance is not a critical issue, use file i/o as the way to share data. This is easy to implement in case you need a fast solution.
JorgeM.
(2,830 Views)
...I meant abovee a fast answer...not solution
normally file i/o will NOT be faster than memory access 🙂
JorgeM.
(2,830 Views)
