several curves with several scales on the same graph
I am currently working on a project which include a data acquisition VI. I would like to display two curves with two different scales (0 to 1 and 0 to 200) on the same graph.
I have been trying nearly all the options in the properties menu, I can not find anything that corresponds to what I want.
Do you know how to do such a thing?
Thanks in advance,
Gabriel.
(2,411 Views)
Accepted by topic author Gabouch
Right click on the existing scale and click Duplicate Scale.
EDIT:  I should add that you'll need to set ActYScl through a property node to switch between the difference scales if you want to run operations on them.
--Using LV8.2, 8.6, 2009, 2012--
(2,407 Views)
