settings missing in INI file
Ravens Fan wrote:
Actually, you have a VI, not a snippet which is a new item that allows actual VI code to be bundled with a screenshot in a .png format.
The problem is that you have a cluster of arrays.  Looking at the help file for the Create RT FIFO, I saw this "Note  If you use a Real-Time FIFO to transfer waveform data, the variant element of the waveform does not transfer because variants are variable-sized and therefore incompatible with the Real-Time FIFO".  I think it applies in your case as well because a waveform is just a special cluster that contains an array.
Thank you Ravens....- We gotta meet-
will you be in Mn anytime >
Message Edited by Jeff Bohrer on 04-09-2010 08:58 PM
"Should be" isn't "Is" -Jay
Message 11 of 11
(338 Views)
