setting scrollbar position for string indicator
Is there any way to set the position of the scrollbar for a string indicator without having to track the number of lines? I am continually updating my string indicator and want the scrollbar to be positioned at the last entry. It seems like there would be an easier method than updating the number of lines.
(3,623 Views)
I did this too and I count the number of lines...
I wrote the attached subvi for this purpose.
The first output goes to the string indicator, the
second to a property node "Text.ScrollPos".
Best regards
Gerd
(3,623 Views)
Hi ss2593,
I had the same problem, which I solved by continually (every few 100 ms)
setting the property Text.ScrollPos = "+infinity". Works great.
-Chris
"ss2593" wrote in message
news:50650000000800000062A40000-1042324653000@exchange.ni.com...
(3,623 Views)
This will help you to count no.of lines of your input string, before writing it to the Text.ScrollPos of the string indicator.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,623 Views)
I had hoped that I was overlooking a simple property setting or something, but that doesn't appear to be the case. From everyone's input, it does look like I need to track the number of lines. At least you've answered my question. Thanks a bunch.
(3,623 Views)
great that my vi did help you 🙂
Ian F
依恩与LabVIEW
(3,623 Views)
