Showing results forĀ
Search instead forĀ
Did you mean:Ā
setting combo box properties through database
dear friends
i am trying for a string control which has combo box type display on the front panel but the drop dowm menu which gives the available option which one can set by going to properties & then to edit option ,but can it be possible to have the same type of front panel control  with the option being there that are a field of the database
thanxs
looking for a early reply
Message 1 of 9
(3,860 Views)
Hi dhiraj034…,
sorry for that, but i don“t understand what you mean. Do you want to write different values to the combo box?
Mike
Message 2 of 9
(3,859 Views)
just as the combo box gives option for the control selection the same option i want to be from a  database field.
Message 3 of 9
(3,857 Views)
Hi dhiraj034…,
i really wanna help you, but i don“t understand it. Can you show a picture of what you want or explain in more detail?
Mike
Message 4 of 9
(3,852 Views)
dear mike
i want a control input on the front panel which shows the options which are a field of a database file to be made input to it.
is it okey now .you can use this control input for a case structure selection button.
Message 5 of 9
(3,846 Views)
dear mike
the combo box gives some selection options which are made by going to the combo box properties & then going to the edit option .after this the combo box will show all the availble option of selection.did u get me ??
or i want a control input on the front panel which shows the option of inputs available in a drop down menu & this list should be from database field of a file
is it okey???
Message 6 of 9
(3,844 Views)
Hi dhiraj034…,
here is an example of what i think it could be. Smiley Happy
Hope it helps.
Mike
Message 7 of 9
(3,842 Views)
hey mike i am using labview 7.1 edition
Message 8 of 9
(3,839 Views)
Hi dhiraj034…,
ok here is a picture, but i“m not sure if it is what you need.
Mike
Message Edited by MikeS81 on 05-08-2008 10:02 AM
Message 9 of 9
(3,829 Views)
