setting chassis for scan mode
Hi
I am building project in project explorer and setting chassis NI cRIO 9103 for scan mode. I select scan mode from properties. In order to deploy new settings, I follow instructions ( right click chassis>>deploy settings), but when I right click chassis the only option I could choose from are New, Arrange by, expand all, collapse all, remove from project, rename, help and properties. I dont have deploy. Am I not following instructions or is there anything wrong?
Thanks for help
Best regards
(3,361 Views)
Sounds like an install problem.  What software do you have on your machine?
Do you have the deploy option on the target?
Sebastian
(3,359 Views)
If I right clack target, i have "disaple autodeploying variables", so shall I assume that Labview 2009 automatically detect deploy scan mode devices under chassis, and FPGA devices under FPGA target?
Best regards
(3,355 Views)
Definitely sounds like some necessary software isn't installed or had an installation problem.  Can you reply back with what you have installed?
You should have installed at least
LabVIEW RT
NI-RIO
and preferably, in that order.
Sebastian
(3,352 Views)
I dont have NI RIO, not sure about Labview RT. I guess it should be installed but I will confirm it tomorrow.
(3,336 Views)
