setting chart autonomus
i want to see my flow data in labview
i can do it by then
but i want change my program autonomus
first of all i should tell you about my data.
my data is rs232 serial communication so  it's baud rate is 115200 and data bits 8 no parity no flow control
but i have end message to verify end of data.
i send few data it is like this
X 1234 Y 4253 Z 3321 [end message]
XYZis nothing just i devide 3data from it. 1234 , 4253 3321 is different data.
i did it!! i can receive this and i can see on chart
but!!! my data can change some time
it can be 4,5,2 data or other num also 3
It is very annoying to change my program every time when the data is changed.
i hope u can  fix this.
thanks
Ha min soo
email: kakashi08@naver.com
(2,909 Views)
Can you psot your actual code and example of your data with the diffrent variations that you see.
Tim
GHSP
(2,891 Views)
ok i'll do that tomorrow morning
(2,882 Views)
txt file is data
first one has 2 data
second one has 3data
(2,862 Views)
