setting Boolean status for selected input response
the string data contains two types of stream response
1. whenever the user send the message --> it will display the response .(Starts from 4 e.g 42101E0000)
2. Continuous response of (8011000000) at every 12s will be displayed.
But I want to display only whenever the user has send message , that specific response and show an status LED .
else nothing to be displayed .
problem is i am not able to make the selection still i am getting both responses
anyone can please guide me ..
thanks .
(2,499 Views)
Post your VI, not a picture.
(2,495 Views)
As @paul_cardinale said please post your vi (also please include the subvis). A quick look at your picture, though, suggests that you should also go and review the training material at the top of this forum. Why are you updating Response using a property node and then updating it again if the value of the string is "True" (I think that you meant to make the boolean to be the case selector input). Have you ran your program with highlight execution on? What did you see?
(2,485 Views)
please find the attached VI ,
yes i am using boolean as case selector
i have run the program execution with highlight ,and i can see that without boolean control also i am able to see the regular response
please guide me..
thanks ..
(2,444 Views)
No, you are NOT using the boolean as case selector. You have the string hooked up to the case selector.
(2,423 Views)
I'm not sure exactly what you're trying to do, but try this.
Also, I changed the boolean to a latching action and eliminated the mess with its reference.
(2,411 Views)
Accepted by topic author Anil@8899
Thanks Paul,
it is working now
(2,370 Views)
