set table header width
I have a pretty simple VI that resizes a MC listbox columns based on the text size. The only thing I don't know how to implement is including row headers. I don't see a property for setting the row header cell width. Suggestions?
Message 1 of 9
(7,776 Views)
Change the ColHdrs[] to RowHdrs[] in the property node, index at column 0 and in the for loop change unbundle to Row instead of Column. DId you try this?
CLD
Message 2 of 9
(7,757 Views)
No, that's not the problem. Think about it, the row headers are actually a column in the table. There is no way to set the width of the "row headers" column in the table. Don't let the property names confuse you Smiley Wink
DId you try running it and see the working form? You will better understand the issue if you do.
Message 3 of 9
(7,752 Views)
Accepted by topic author GregFreeman
Column = -1
Message 4 of 9
(7,745 Views)
@Darin.K wrote:
Column = -1
Let me guess...it's in the context help?
Message 5 of 9
(7,740 Views)
You'd have to tell me, I just guessed.  Smiley Tongue
Edit:  Now that you mention it, the Detailed Help is actually quite informative here.
Message 6 of 9
(7,737 Views)
Column = -1 will set the header of the first row but how will iterate through the next header? Will the loop alone will do it if the iteration count increments to second row?
Sorry this just got me curious!!...ofcourse after understanding the problem Smiley Happy
CLD
Message 7 of 9
(7,719 Views)
I do not know if I got your question right...but have tried this.
It will increase row headers width.
Let me know if this is what you want...
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 8 of 9
(7,702 Views)
Yes, it looks like -1 works. I guess I just wont be able to use an autoindexed array and the counter, because the counter is unsigned. I'll just make things easy and have a second for loop to size row headers that does the same thing as my exisiting loop but has -1 wired up to the column index. Also, just a note for you, property nodes are expandable, no need to have another node for width, just drag it down 😉
Message 9 of 9
(7,683 Views)
