set resolution
i have attached 3 pictures here
1 image is in the developemnt mode
2. image is in running mode
3. is how i set the windows size
need help in development mode the screen images like labels all look ok but run
mode is not ok. why and how can i fix it? plz help
Message 1 of 12
(6,917 Views)
Attachments missing
Message 2 of 12
(6,916 Views)
sry attached here
Message 3 of 12
(6,906 Views)
I asume that your VI is running on a smaller display than your development system. Please note that text size does not resize if the panel is being resized. Therefore, text is "misplaced" and moved around on the panel, in case of free labels even "cut".
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 4 of 12
(6,893 Views)
it also happens to some of the controls resize not as development.. how to fix this problem?..need help
Message 5 of 12
(6,878 Views)
Post your VI.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 6 of 12
(6,875 Views)
Did you check (select) the options in the Window Size category in VI Properties?
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 12
(6,865 Views)
Oops... ! Sorry, did not see your attachments.
Message 8 of 12
(6,863 Views)
Partha she already attached.
Balaji PK (CLA)
Message 9 of 12
(6,862 Views)
Does your devp PC & the other one running with the same OS?
Message 10 of 12
(6,861 Views)
