set boolean Button as defult
Hi all :
Attached please find , when you run the vi don't used mouse click , press enter from keyboard to exsit .. as you see the defult button is "stop Test" .. who i can change  when i press enter the defult button will be "Repeat Test"
set Repeat Test button as defult
thanks
Message 1 of 12
(4,329 Views)
Use a Key Focus property node.
right-click on Repeat >> Create >> Property Node >> Key Focus >> click on the property >> Change to Write >> wire a True constant
Message 2 of 12
(4,327 Views)
thanks a lot
Message 3 of 12
(4,323 Views)
Hi :
Attach see file , when i press on enter key from keyborad , the defult key is cancel ,, what i need to set ok button as defult
how can i do that
thanks
Message 4 of 12
(4,256 Views)
Did you try kb's suggestion?
Message 5 of 12
(4,252 Views)
what , how can i do that
Message 6 of 12
(4,244 Views)
muks did you mean jb's suggestion?Smiley Very Happy
Message 7 of 12
(4,232 Views)
I didn't look at your original code.  But if you have a button called "repeat", then simply follow jb's instructions.  On the block diagram, find the terminal called repeat and right-click on it.  Then follow the rest of the instructions.
R
Message 8 of 12
(4,219 Views)
Hi :
attach see file ,, how can i when i press on enter from key borad , the application stop , vi wxit from loop and stop , i don;t want to use mouse click
thanks
Message 9 of 12
(4,176 Views)
Hi elyan,
you can use the key down event. See the attached example.
Mike
Message 10 of 12
(4,174 Views)
