server does not support remote panels
I am developing an online laboratory setup and hence am using a client server model..the client VI being accessed by remote users online. I have done all the necessary steps using Web Publishing tool and the configuration set up. I have also tested the VI previously online. Suddenly now when I hit the URL for the VI the panel does not load...it says Server does not support remote panels. What could be the problem?
(3,371 Views)
Is the web server configured/enabled on the remote computer. Also has anything changed in the network connection. Also you might want to try a different port. You might have installed something that is now using the port that you configured. Usually 90 will also work. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,371 Views)
Thank you!!! I did try few port #s and port 93 did work!!
(3,371 Views)
Sometime you are restricted to what ports can be used and might have to search. Glad I could help.
BJD1613
Philips Respironics
(3,371 Views)
