server and client in website
Hi
I have a problem about the web browser. I use daq card to perform datalogging continuously without delay. And I try to apply the web publishing tool to have remote display and control through the internet. When I connected to the server computer through the internet, the front panel show up and then have a error message about the client computer can not catch up with the server. I have to refresh to update the front panel in client computer and then got the same message. Is anyone can tell me how to solve this issue? Thanks
Fred
(2,740 Views)
I had a similar situation on a project last year. I was using Labview 6.1 on a Win 2K machine. After speaking to Austin, we came to the conclusion that I was feeding too much data at once to the server, and it was over-running the capability of the remote client. In my case, I had a HUGE number of controls on the panel to be displayed,and the server built into Labview was suposedly not designed to handle such large amounts of data. I upgraded to Labview 7.0, and it cured the problem for me. I don't know if this is your problem, but that was my experience with the same error situation. BTW, in addition to the Labview upgrade, I cherry-picked the data that I was sending, as a precaution the ensure I had enough head-space to accomodate future requirements.
D
ave
(2,740 Views)
Hi, Dave
Thanks for your sharing experience. I am using labview 7.0 right now for my project. The data I feed to the server is data sets, which should be less than yours. I will try to do some modification according to your experience. Thanks for your help again.
Fred
(2,740 Views)
HI Fred:
Good luck. Austin told me that the web server built into Labview was sort of a "Server Lite", and not intended for heavy duty serving applications. They didn't elaborate on that, but I found that I had to reduce my served data by about 60% before I got reliable continuous remote display. I looked for an alternative, but was in a time bind, and could not spend the amount of research time on this that I would like to have. If you come up with a better usable server application, please let me know, as I expect to have a similar application in the works in the next few months.
Have a nice day
Dave
(2,740 Views)
