serial visa resource empty
saludos comunidad de ni
Estoy teniendo un problema con el resource name de un vi, exactamente mi problema es que aparece vacia la lista de los puertos com, pero utilizando un programa para testear el serial funciona correctamente, lo cual me dice q es problema de labview y no del driver del puerto.
Eh estado buscando en el foro pero no eh encontrado mucha informacion.
agradesco de antemano su ayuda..
Mensaje editado por ferock
(3,357 Views)
Accepted by topic author Prodtos
(poor) English translation:
greetings or community
I am having a problem with the resource name of a saw, exactly my problem is that it appears empty the list of com ports, but using a program to test the serial works correctly, which tells me q problem is not the driver and LabVIEW the port.
Eh been looking at the forum but did not find much info huh.
agradesco in advance for your help ..
Message edited by ferock
Have you verified that:
  1. VISA has been installed
  2. The serial ports show up in MAX?
(3,335 Views)
another translation:
"I am having a problem with the resource name of a VI, exactly my problem is that the list appears empty for the serial ports, but using another program to test the serial ports works properly, which I why it seems the problem is with LabVIEW and not the driver of the serial port.
I looked for a solution in the forum but did not find much more information on my problem."
As Smercurio asked, did you install NI-VISA?  From your description, it appears that it was not installed.
Can you see the serial ports under devices inside MAX (Measurement & Automation Explorer)?
Portugese:
Como Smercurio perguntou, você instalar NI-VISA? Desde sua descrição, parece que ela não foi instalada.
Você pode ver a portas seriais em dispositivos dentro MAX (Measurement & Automação Explorer)?
(3,314 Views)
