serial to parallel converter in labview
Hi. Does anybody know how to convert serial data to parallel data using labview? I already used shift registers but it's not working.
Message 1 of 10
(6,264 Views)
We probably need much more details.
(have a look here for some ideas)
Message 2 of 10
(6,257 Views)
i just want to convert 1 bit serial binary data to parallel.
Message 3 of 10
(6,247 Views)
i just need to convert binary bitstream into parallel. Can I use for loop for shift registers? If so, how can I use it?
Message 4 of 10
(6,225 Views)
To "parallel" what? Are you talking about an output interface or a data format? Please be much more specific? What is the data format of the "bit stream"?
What makes you think that FOR loop and shift registers are the anwer? That sounds pretty vague. What do you have in mind?
Message 5 of 10
(6,219 Views)
I want to convert it to parallel boolean (true or false) by storing one bit of binary data in every registers so i can combine it in 1D array.
Message 6 of 10
(6,198 Views)
Message 7 of 10
(6,190 Views)
You still need to be much clearer. LabVIEW does not have "registers". LabVIEW is a programming language, not a circuit simulator.
What is the datatype of the serial data? booleans, bits, bytes, U8, etc.
What is the datatype of the parallel data? 1D array of what? How big can it get? What do you want to do with it?
Do you get one boolean at a time and simply want to append it to a boolen array? That would be trivial. What have you tried?
Message 8 of 10
(6,163 Views)
You should gather/generate your data inside the loop, then when you wire it out of the loop, right click the tunnel, select tunnel mode -> indexing.
This might do what you want it to.
-Jim B
Applications Engineer, National Instruments
CLD, CTD
Message 9 of 10
(6,083 Views)
I'm thinking this is what he's asking but it sounds like another homework question so I'll also ask:  Show us what you have tried.  Post your attempt and we'll help you through it.  This is an easy task but it requires some knowledge of basic LabVIEW structures.  If you're a new LabVIEW coder we can certainly explain things for you but you do need to show us your effort.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 10 of 10
(6,054 Views)
