serial read inserts carriage return
hi
i tried to read data from an eprom over the
serial port. this works fine with visa, but
for every \10 (linefeed) i read labview inserts
a \13 (carriage return). i've no idea how to
turn this "feauture" off, tried to change sth.
in the property node, but nothing worked.
can somebody help me ?
greets krzysztof
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,057 Views)
krzysztof8048@my-deja.com writes:
> hi
It´s not a big issue with text (A-Z etc) interface languages because
both normally mean "end of message". Try some of the string functions
for replacing. I like this VISA "feature", because I don´t have to count
bytes to read. Put in a big number and you will get anything available
without a timeout.
With a binary (\0..\255) interface you are in trouble. I have to
address this issue in my own application. Thanks for remindin
g me. VISA
allows message end characters and has a different property for
switching them on or off. The property node is the right place to
start searching.
Please tell me the solution.
Johannes Niess
(3,057 Views)
moin
i have indeed to read raw binary data, up to now i have solved this
problem by simply removing the \r when a \r\n (\r is a carriage return,
\n is newline) was received with the match pattern vi and the string
subset vi.
but i've just found out that this is not a solution, the problem
is that labview not only changes a \n to \r\n but it also
changes a \r to \r\n , so i don't know if i've go a \r or an \n when
reading a \r\n, now i have really a problem.
In article ,
> > hi
count
available
> without a timeout.
> address this issue in my own application. Thanks for reminding me.
VISA
> start searching.
> Johannes Niess
(3,057 Views)
krzyszto@vis.ethz.ch writes:
> moin
> subset vi.
That´s a serious bug. It makes a lot of my work useless. I had a
long discussion with dan.mondrik@natinst.com about VISA (serial)
locking (on the mailing list). He promised a followup. It turned out
that locking isn´t totally based on sessions
. The same is true for
properties like baud rate etc. It looks like _all_ ways to do serial
I/O in LV have bugs.
Did you try the end char properites of VISA?
Johannes Niess
(3,057 Views)
It´s long time ago, you asked your question, but I have a similar problem, maybe the solution helps some other guys.
Solution:
I use Visa Open, Read Write Close etc...
After Opening I use a property node to:
Set FlowControl to none (maybe its not really necessary)
Set SerialEndModeForReads to none
Now it works.
Stephan
(3,057 Views)
