serial read information problem
hello!
I have a problem with the serial port: when i use the hyperterminal everything is good, i have no problems. But when i try to comunicate with the hardware , using labview everything is wrong. Sometime it work, sometime it's time out, it's completly random.
Thank youk for your answer
(and excuse my english)
(2,784 Views)
There could be a problem of termination character there. Check if your serial port config is allright when using it with LabVIEW.
Tell me a bit more about your problem, LV version, hardware and I'll try to be more precise.
Hope this helps anyway !
Julien (French if that can help you)
(2,784 Views)
Merci
J' ai résolue le probléme et c'était bien un pb de config série, bien vu!
Merci encore pour la réponse
salut
(2,784 Views)
