serial port data bits problem
Now I am using the VISA Configure Serial Port to initialize the serial port. The value of data bits is between five and eight. The default value is 8. But I need to transfer nine data bits once ( the ninth is direction bit) .I wander how to realize this purpose. Appreciate your help!
(3,843 Views)
I had not noticed it before !
It is not a problem of Labview. Hyper-terminal allows you up to 8 bits too.
So it is a PC limitation.
Solution: Send the number nine bit, to a new byte. You have to configure your hardware accordingly, to read the new byte.
If you explain more, what you are trying to do, maybe i can help more.
(3,838 Views)
you could use the property node  parity to go through the nine bit transmition.
pay attention that have some 2-6ms delay before change the parity after send the direction bit.
I have no VI at hand. if you need , i can upload latter
gg@ggdyb.com
朗圣自动化科技
数显电测仪表专家
(3,823 Views)
A search of the KnowledgeBase can turn up answers: How Can I Do 9-bit Serial Transmission Instead of 7 or 8 bits?
There is also a link to an example in the article.
(3,820 Views)
Hi,PntgaogonghmSmercurio ,thank your very much for your kindness and I am trying those recommended methods. Hope to solve this problem !
(3,797 Views)
