serial port break interrupts the ethernet communication
The serial port break on my com1 port stops the TCP/IP transmission on the ethernet communication.
I am using a 26 ms break to have a 26 ms low on the serial port. This is needed by the serial device on the com1.
The ether net connection is used to communicate to a second computer. The link to the second computer is lost when the serial port break for com1 is sent.
Message 1 of 8
(4,307 Views)
hi there
please post some code
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 8
(4,286 Views)
TestCell7: is the ethernet connection
test1 is the testing sequencer that has the subvi to the RS232.(comms)
these are running at the same time.
Message 3 of 8
(4,264 Views)
Ok,
I did not get all the vi's in the last message.
they are all here.
Message 4 of 8
(4,263 Views)
i'm sorry, i hoped to see something without hardware, but i had no success.
Best regards
chris
Message 5 of 8
(4,252 Views)
I couln't get the VI "TestCell7" to run consistantly, plus I don't have a second computer running that would connect (TCP/IP) correctly to this VI, so I tried running a few things with some of the example VIs that may simulate what you are describing.
I tried the simple data client/server VI's allong with "Set Break.vi" that ship as example code with labview.  The simple data client/server VI's were set to run on the local host and at port 5004.  I did not see any conflict with setting the break on the serial port with the connection of the client/server.
I would suggest trying this out the examples on your connections and see if you can repeat the problem.
Message 6 of 8
(4,242 Views)
this is and intermitten problem.
I have run the vis  together for an hour with no problem.
Then I will get 5 to 10 min of ethernet link loss. Always at the point where I send the Visa Clr.
When running the programs individually there are no interrupts.
The program with the serial break has been running for 6 mo. with no problem.
The Ethernet has been running for 4 weeks as a stand alone.
the problem occurs when I run them together and only once or twice an hour.
Message 7 of 8
(4,223 Views)
I ran these on my desk simulating the connection with a client/ server set-up.
I did not have any interrupts.
Only when I set it to actually running with 2 computers does this fail.
The other computer is polling the TestCell7 Vi every 100 to 800 msec. I have no control on this timing.
Message 8 of 8
(4,221 Views)
