serial monitor
I don't sure about baud rate and everything for gcviewer.exe.....How can i check?
Is it possible to check Baud rate, data bits, parity, stop bits, flow control from device?
I put    Baud rate 9600
           Data bits 8
           Parity None
           Stop bits 1
           Flow control None
Please give me some advise...
Thanks!
Message 1 of 9
(3,748 Views)
Hi Melikyan,
you can set it at start up of your vi. Can you upload your vi??
Please reply to this post, and don´t start everytime a new one. Smiley Happy
Use the "reply button"
Mike
Message 2 of 9
(3,747 Views)
Hi Melikyan,
for more information see the provided example. "basic serial read and write" or "advanced serial read and write"
Mike
Message 3 of 9
(3,741 Views)
Dear Mike. I attached the Vi. I use Labview 8.0.
Thanks for your kindly attention.
Message 4 of 9
(3,732 Views)
Hi Melikyan,
it looks good. What error did you get? Could it be that you have to send "CRLF" at the end of your string? I don´t know what your device expected.
Mike
Message Edited by MikeS81 on 04-19-2008 11:01 AM
Message 5 of 9
(3,722 Views)
Dear Mike actually the exe work like this....First time i Push "connect", second time "Load current"...and after that i get the data...
But Labview i use only 1 time Run button....
I attached 2 xls docs. I run by .exe and labview....and here i saved by serial monitor...Data is very big...But if for u not difficult could you show my mistake?
Thanks...
Best regards
Harut!
Message 6 of 9
(3,718 Views)
Hi Melikyan,
where are your problems now? Does the communication work now? If you send a command from LabView to your device (only one at the moment), do you get the expected response?
Mike
Message Edited by MikeS81 on 04-19-2008 11:14 AM
Message 7 of 9
(3,713 Views)
The problem is i can't read any bytes....Byte count equal 0.
And now i can't check where come from the problem...
I used serial monitor program to check whole process.....Labview command request, but can't read...
I try compare commands from serial, if you can see the xls files Row 42 the write commands go to device different, i compare 2 files...Main part are same, but some parts are different....And everytime i push run, everytime codes changed.....Main hexacodes are fixed, everytime fixed and stable...But some are not fixed and after every run changes.....What is the problem?
Do you have any idea?
Message 8 of 9
(3,705 Views)
Howdy Melikyan,
Your LabVIEW code looks fine. If the instrument doesn't respond as you expect, one (or more) things could be the culprit:
  • Improperly terminating the command string sent to the instrument (most-likely case)
  • Sending an invalid command to the instrument
  • Improperly configuring the port settings for the instrument
Regarding the first possibility - at the end of each command you send to the instrument, you must verify that you have the proper termination character. Typically a \n will do the trick. Other termination characters include \r, \r\n, and \f. I'd be willing to bet that adding a termination character to the end of your command will get a valid response from the instrument.
If the instrument doesn't reply after adding a termination character, you might want to consult its manual for a simple command that you can send to test communication. For example, some instruments will have a reset command that you can send that will cycle the instrument's lights just to kind of verify that communication to the instrument works properly.
I hope this helps!
Warm regards,
pBerg
Message 9 of 9
(3,645 Views)
