serial communications problem
Hi,I like to try your vi (Test RS-232 Serial Communications.vi). But it is for LabView6.1 and I only have LabView 6.0. Do you have it for LabView 6.0? Thanks a lot.
Message 11 of 12
(589 Views)
I made a short look at your VI. JB's answer is the one thing I also have seen.
Another thing is setting the parameters for the communication.
In hyperterminal are the flow control (SW/HW handshake) also disabled? You configured the baudrate and byte parameters but the flow control is set to default which means no handshake.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 12 of 12
(589 Views)
