serial Send speed
Isn't it easier to set 255 as termination char?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 24
(1,898 Views)
He / she needs to start reading when 255 encountered
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 24
(1,892 Views)
I did that but the transfer rate didn't change... (3 or four sets per seccond).
Message 13 of 24
(1,886 Views)
Well how big is a set? How much data is discarded? How much data do you actually recieve?
2MB ~ 200kb of text.
/Y
Qestit Systems
Message 14 of 24
(1,882 Views)
I added a little information, how does this work?
/Y
Qestit Systems
Message 15 of 24
(1,872 Views)
I attached an image from the front pannel when the program is running.
as you see the "bit/sec" indicator shows 188717 but it sometimes changes to 188008 bit/sec.
Message 16 of 24
(1,857 Views)
What is the problem? You are successfully communicating at 2Mbaud. You don't get any errors. You don't get a buffer overflow so it would appear you are keeping up with whatever is transmitting.
What is actually transmitting? How big is each packet? How often is each packet sent?
Message 17 of 24
(1,852 Views)
It's supposed to recieve 2,000,000 bit in every seccond but as you see in the JPG file the transfer rate is 188717bit/sec not 2mb/sec!!!
The transmeter sends data in a row continusly and the VI should start to read 5000bytes after recieving a "FF" byte and then after recieving consequent "FF" it recieves another 5000bytes and so on....
Message 18 of 24
(1,837 Views)
No.  Your indicator is showing BYTES per second.
It looks like you should have about 11 bits per byte based on having 1 start bit, 8 data bits, and 2 stop bits.
Message 19 of 24
(1,832 Views)
In other words ~2,000,000 bits/sec, or ~188717 bytes, with start and stop bits.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 20 of 24
(1,826 Views)
