separate string character
Hi I have a litle problem!
I wrote in the first vi data text,then I saved the data into a "write characters to file" , and then i want to open other vi with the data and put each data in the text control, but i dont know how can i separate each initial box to put in the correct box text. Any help?.
I attachment the 2 files example. For sure its very simple, but i am became mad!!.
Other question is how can i to transform any vi to icon with terminals to use into other vi?.
I made a vi, and i want to use into the other vi with the input as terminals to run it well.
I wait your answers! thanks guys
(2,916 Views)
I cant open your VI since I am using 6.1. For your second question, click
here
. I still not clear what you try to do. May be my English is bad.
When you feel sad, laugh
(2,916 Views)
Hi nayisoe, thanks for the reply.
Maybe my english is worse than your english. 😉
But thanks, the movie is PERFECT!!.
In the first question, I write all the characters in the file, but when i open the file all is join and i dont know how can I remove the first test that i saved, this first text is the first square test...
I attachment the pics of vis.
I want to read from file,and the name, number and code show in the text box, but i dont know separate the string, it appear united totally.
Sorry for my english, regards from Spain.
(2,916 Views)
Think example says more than words. See attached below. Hope it help.
(2,916 Views)
Yes say a lot.... thank you very much! and the faster reply!.
Best regards.
(2,916 Views)
