separate 2d array dynamically
Hi all
         i have a 2d array of string values (please refer the vi). I want to separate the array into 1D array of values based on the date dynamically.  I tried few options but nothing seems to work dynamically.
thanks
senthil kumar
Message 1 of 11
(5,786 Views)
Hi Senthil,
Your attached VI has only empty array. When you have data in the control, please make it as a default value and then attach the VI.
If you have tried anything in blockdiagram make sure that is also available.
Nanthakumar
Message 2 of 11
(5,775 Views)
Provide more info:
-What is the input data?( Fill the data in control and make the data to default)
-What have you tried?(Post what you tried and what didn't work)
-You can try for loop, Search operations and auto indexing options to separate and build arrays.
uday
Message 3 of 11
(5,771 Views)
sorry forgot to save the values in the array
Message 4 of 11
(5,769 Views)
hi
  i tried using indexing, and it does not work as intended and dynamically
Message 5 of 11
(5,766 Views)
I repeat:
-What you tried?(and didn't work?)
-You have 2D array of string data, You want to separate(based on what condition) to 1D array of what?
-You mean to say you keep some date as threshold and separate array elements prior to that and after that?
-Put sample data with both control and indicator(s) and what you expect in indicators then it would be easier to suggest.
uday
Message 6 of 11
(5,750 Views)
Dear udka
                 I tried on it for few hours, i cant put everything here.
                 I want the values to be sorted out based on the date.
                 sorry not 1D array but 2D array of string
                 I have attached a vi here with input and expected output
thanks for the help
regards
senthil
Message 7 of 11
(5,742 Views)
Hi Senthil,
Data will contain only 3 dates you have given? If it has other dates what will you do? You may need to create more 2D array indicators dynamically. Think about the data structure.
Nanthakumar
Message 8 of 11
(5,733 Views)
You can group the values like following.
Nanthakumar
Message 9 of 11
(5,726 Views)
hi
   It is working good, but the first value is again repeating as the last value. can you post the vi. I think i am missing something here
Message 10 of 11
(5,695 Views)
