sensing pressure with 24PC using labview
i want to monitor  pressure with 24PC pressure sensor  using labview,but it give output in milivolts which is deeply buried in noise,how i can get rid of noise
(2,604 Views)
Hi 1487,
-use an amplifier for your sensor output
-reduce noise by using better/shorter cables
-reduce noise by applying a more stable pressure (by less flow?)
-use some averaging (aka low-pass) filter
It's almost easier (and surely more effective) to suppress the noise at the signal source instead of trying to reduce the noise by averaging the measurement data...
(2,603 Views)
