sending data to array (Bascic question)
I need to send the data from Mean.vi to an array as the values are generated. How would this be achieved??
(3,018 Views)
You must be able to do this by using a shift register and inserting data into the array from the Mean.vi.
(3,018 Views)
Here is an example of how to use a shift register to build an array on the fly inside a loop. Use the output of your Mean.vi to replace the random number generator in this example. Don't forget to initialize the shift register before the loop as shown in the example.
- tbob
Inventor of the WORM Global
(3,018 Views)
Thanks for your suggestion.
Unfortunately I�ve got Labview 7 and cant open the example you posted. I get an error message say i need version 7.1 to open the file
Can you post a screen shot of the block layout
Thanks again
(3,018 Views)
Here is the LV 7 version.
- tbob
(3,018 Views)
