sending and receiving values using web services vi
hi trying to receive values  values using the webservices vi 's, but im facing same conversion errors. im sending my project and an image of the problem can anyone help me on this?
(2,647 Views)
Here is a global tutorial about Web Services :
http://zone.ni.com/devzone/cda/tut/p/id/7350
There are exemples at the end of the document : webservicesdemo.zip
Please check the instruction for using web services given in the Readme.doc, it could be the source of your problem.
Also, mind that you need the same language for you labVIEW version than the one used to create the Web service VIs.
(2,587 Views)
