10-18-2005 01:26 AM - edited 10-18-2005 01:26 AM
메시지가 10-18-2005 01:27 AM에 labmaster에 의해 편집되었음
메시지가 10-18-2005 01:28 AM에 labmaster에 의해 편집되었음
10-18-2005 01:59 AM
10-18-2005 02:54 AM
10-18-2005 07:01 AM
10-18-2005 10:21 AM
After converting to U32, you need to reverse the bytes for each number. There are many ways to do this, one possibility is attached (LabVIEW 7.0). After that, you simply need to cast it to a string.
The attached example shows how to convert your input to a big or little endian string of 12 bytes. You probably want the little endian (LSB first), but please verify. LabVIEW is always big-endian, even on intel (which is typically little-endian).
