semaphore Help
Anyone have a simple example of semaphore for LabVIEW 6.1? I need to know how to enter 2 user data using the semaphore method. The user juz need to enter simple addition sum. can someone help me? thanks alot...
(4,051 Views)
..\LabVIEW 6.1\examples\general\semaphore.llb
(4,051 Views)
how am i going to see the file.. cos i think i do not have this directory... tks...
(4,051 Views)
you should have those examples, if you choose to install LabVIEW examples while installing LV6.1.
If you didn't, launch the installer again and choose examples. Do you have full developement system or professional dev system of LV?
(4,051 Views)
This software is actually install in my school therefore i think i do not have access to the software... Btw, are you referring to the Semaphore with sub-vi example? I have read it... i try using the example to build mine own task... it didn't work..
(4,051 Views)
lyloh wrote in message news:<5065000000050000005A040100-1042324653000@exchange.ni.com>...
Have you looked in the national instruments developer zone. Check out
the development library or search in the code sharing area.
http://zone.ni.com/zone/jsp/zone.jsp
(4,051 Views)
