selective clean up for block diagram
Is anyone aware for selective block diagram clean up in labview.
I dont see this feature as of now.
Do let know if any one is aware of this .
Sundar,
Message 1 of 8
(3,779 Views)
I think selectie block diagram clean up works nearly perfect (better then cleaning up all).
In LV2009 just mark your region of interesst and press Ctrl+U...
Message 2 of 8
(3,774 Views)
See here.
Message 3 of 8
(3,763 Views)
Sundar what is your lv version?
Message 4 of 8
(3,752 Views)
I am Currently Using LabVIEW 8.6
Message 5 of 8
(3,732 Views)
Hi Sundar,
Like the others said, selective clean up is a feature of LabVIEW 2009.
The clean up in your version will clean up the whole block diagram even if you were to select a part of your block diagram.
Mithilesh Pradhan
Message 6 of 8
(3,711 Views)
Hllo Sundar,
As Mithilesh said correctly LabVIEW 8.6 doesnot support feature of selective cleanup. Even if you try to clean selected area of your code it'll clean all terminals and nodes present in your VI.
Message 7 of 8
(3,674 Views)
I guess  I need to wait for the upgrade for LabVIEW 2009 to try this :(.
Sundar.
Message 8 of 8
(3,662 Views)
