selection
How to make if single phase selection will link to single phase table and three phase selection will link to three phases? And display result will only display for one selection either single or three phase. The combo box cannot be edit in block diagram.
(3,398 Views)
Hi farah,
what about using a case structure? Such a structure allows several cases to be executed depending on a condition…
Btw. I would suggest to use an Enum instead of a ring or combobox…
(3,393 Views)
hi thank for reply.
how to make case structure for this?
(3,385 Views)
@farah88 wrote:
hi thank for reply.
Do you know how to make a case structure in general?  Use the combo box value (agreed that it really should be an enum) wire up to the selector terminal of the case structure.  You will want to create a case for each algorithm and use the same output tunnels that are then wired to the indicator terminals.
(3,383 Views)
