selecting item in the menu ring will disable in the another menu ring
hi everyone,
                      I using 8 dialog check box and 8 menu ring (Items 1,2,3,4).If i make the 8 dialog check box 'true' condition the corresponding  menu rings will enabled .In that menu ring  the selected item (1 or 2 or 3 or 4) will disable in the another menu ring.how to get an optimum solution?
                                                      Thanking you,
Kumar.
(3,506 Views)
Dear Kumar,
The information you provided is a bit vague, and makes it difficult to help you.  Please clarify your requirements and add a diagram if applicable.  Also, please keep in mind that there are property nodes which allow enabling and disabling of controls.  I believe these property nodes can be useful for your application.
I look forward to hearing back from you,
AG
(3,483 Views)
hi ag,
          I attached the basic vi of my application.what should be the action is the selected number in the menu ring(1 or 2 or 3 or 4 or 5 or 6 or 7 or 😎 disaable in another menu ring.
for example,
                    If i select the numer 1 in the menu ring 4 the other 7 menu rings disable the numer 1.after fourth selection the other four menu rings disable the numbers 1,2,3,4.The selected four menu rings does not disable the number 0 it will consists the selected value & 0.
If i choose the 0 in the  menu ring 4 .the other menu rings visible the number 1.
By,
kumar.
(3,470 Views)
Hi Muthu Kumar,
You will be able to realise what you are trying using a property for the ring called Disable Items ( look at attached pic)
using this property node, I am sure that you can think of a logic/program to achieve what you are trying to do
Regards
Dev
(3,468 Views)
hi devchander,
                      By making any 4 rings with values(1,2,3,4) the disable items property  works correctly in that application . But after make all menu rings value to 0 the other numbers(1,2,3,4) are disable in first click(mouse down event).it appear after the second mouse down event only why? and
eg:
 rings              values
ring 1               4
ring 2               3
ring 3               1
ring 4               2
ring 1              0
but still  other menu rings are disable the value 1.how i enable it?
by,
kumar.
(3,462 Views)
If i Understood your query correctly, you are asking 'why is not the change disable/enable happening instantly once you perform a mouse down? '
Understand this funda: In the ring, first the mouse down event occurs and only then, value of the ring changes.
so when you do mouse down, the event case is entered and the code in it is executed.
However since the value change has not yet occured, your local variable will still be holding the previous value of the ring
hence you observe your desired result on the next mouse down operation
I suggest you keep this 'all ring indexes =0' check in the time out case and give a finite time out value ( Ex: 100 milli sec), instead of keeping it in a 'mouse down' case
Hope this helps
Regards
Dev
Message Edited by devchander on 08-11-2006 02:51 AM
(3,454 Views)
