selecting Execution Target Option not appear
I have the LabView 7.1 on PC. the Real Time is viewable to me in the "Measurement and Automation Explorer" . I can see the the devices which are present in the Chassis, but when I start the LabView 7.1 for prog. the "Execution Target " Selection Combobox is not Appearing on the window. Can any help how to configure this in my LabView so I can connect the Real Time.
(3,068 Views)
You need to install (re-install?) the Real Time Module.
MAX can see the board by itself, but LabVIEW can only work with it if the RTM is installed.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,061 Views)
Thanks for your Reply, But I have one query, I am new to the LabView Environ ment. Can you pls, explain me where to install the Real Time Module. whether on the PC or in the Chassis. & how to install it , whether I have to connect my PC to the Chassis physically with Ethernet Controller. & reinstall the Real Time Module through MAX (Measurement & Automation Explorer ) ?
Thanks & Regards,
Sandeep
(3,060 Views)
The RTM is a software add-on to LabVIEW.
You should have purchased it with your RT board.
It's a separate product, on a separate CD.
Steve Bird
Culverson.com
LinkedIn
(3,055 Views)
Yes We have the Real Time Chassis & the CD Set of Full Dev. System. 1 cd of Full Dev. System & 2 are Device Drivers . I have the updated device drivers on PC other than the drivers come with RT chassis. Can you tell me whether it is compatible with the new drivers ? I have the version of new drivers 7.4. on PC & the chassis have the version 7.1
Thanks & Regards,
Sandeep
(3,056 Views)
It's not a device driver - it won't be on the same CD.
It's a separate product. This link is for the LV 8.0 version - you will have to look around or call your rep for the 7.1 version, or else upgrade your LV 7.1 to 8.0.
Steve Bird
Culverson.com
LinkedIn
(3,050 Views)
