select which VI to use with a dialog box
Hi!
I have one programme that acquires data and an other that analyzes data, and I want a dialog box to appear when I run the VI so that I can choose which programme to use. Kind of like a small start menu with two options.
Maybe use a case structure and the buttons in the dialog box is true or false?
Thank you in advance!
(2,828 Views)
PS if you give a graphic answer please use Labview 7.1
(2,826 Views)
Use Two Boolean controls in the front panel & kept the two vi's(Acquire & Analyze) in the event structure value change event of its .
or
Use state machine method.
See attachment
-Kumar B
(2,819 Views)
Find the attachment for state machine example.
-Kumar B
(2,818 Views)
Thank you so much! I think this is just what I need 🙂
(2,812 Views)
